engine break-in - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-04-2002, 08:15 PM
E.T. divided by $ spent= Speed
Post engine break-in
I'm getting ready to drop in my new 350(literally last motor homemade-hoist broke). I'm hearing that to break in the cam your supposed to hold the car at 2000rpm for 15min. Whenever I've installed a cam befor I never did this and the other motors ran fine.Is this really nessisary on a hydraulic street cam??
Old 06-05-2002, 06:10 AM
New Member
Post
Yes,and use plenty of cam break-in lube on all the valve-train pieces,change oil and filter after about 100 miles or so...
Old 06-05-2002, 10:54 AM
F-1Rodder's Avatar
Post
The most critical issue is the cam lubrication. Use plenty of cam lube provided by the supplier or assembly lube. Really slop it on. Next, fill the engine with oil and get a pre-lube shaft that inserts in the distributor mounting and put an electric drill on the pre-luber and run it until you see oil coming out of your rocker arms on both sides. This will indicate that oil pressure is present throught the engine and that your pump is working. Re-install your distributor and start the engine. Be sure your rockers are not too tight. They should clatter a little at this point and run the engine for a half hour at 2000 rpm. Note that the cylinder walls are lubricated by crankshaft splash, so this is why you do not want to idle the motor, it needs to splash the rings. Watch your temperature and oil pressure. Now adjust your pre-load on your rocker arms to the desired load. Clean up the mess in your engine bay, put your valve covers on, change oil and change filter. Now drive it. Vary you engine speeds and do not let it idle a lot. Just a nice country drive. After you have 500 miles on it drive it like you have just stolen it.
Old 06-05-2002, 04:41 PM
Post
When I installed cams befor I always soaked the lifters in oil, put cam lube on and primed the motor for 5min or so.Fired it and adjusted the lifters.Then changed the oil after 100,500 & 2000mi. But had never ran the motor at 2000R's for 30min. I always just let it idle wile i set timing and adjusted the air/fuel.On the rings I used to oil the cylindr bores.Smoked like hell for 5min. but seemed to work.?
Old 06-05-2002, 05:45 PM
Wiki Edits: 49
Post
Next time read the break in procedures that come with your cam. Almost all manufacturers recommend running the cam at 1500 - 2000 RPM for 15-20 minutes at initial startup. This is the break in. If you don't follow their recommendations you may have premature lifter wear or even flatten a lobe on the cam. If you havenít had a problem so far, youíve been very lucky.
Old 06-05-2002, 06:09 PM
F-1Rodder's Avatar
Post
Follow the mfr. recommendations. But if you are assembling a stock motor, the spring pressure is not usually as high as with a performance cam and may not be as critical. I read about a lot of guys that do it wrong and end up paying for another cam and more lifters.
