Engine break in with low tension rings - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-10-2013, 08:24 PM
Banned
I know to start off with dyno oil.. for the first 500
I always run it, an hour or 5 then drain and refill with new filter and then go 500 miles, then drain then switch over to syn..
is there any difference in break in with low tension type rings..
the cam break in, is not an issue here as it's roller..
Old 05-11-2013, 06:42 AM
1Gary's Avatar
Last journal entry: 383 dyno sym
Not second guessing you.Curious is my nature.Why low tension rings??. Because of the pistons??.
Old 05-11-2013, 08:53 AM
Banned
because thats what g.m. installed, or so I'm told..
in the #12530283 vortec 4 bolt main truck 350 (96-02)
Low oil pressure during cam break in truckboy61 Engine 12 12-10-2010 09:06 PM
Engine rings davidwobken Engine 1 10-10-2005 09:55 AM
Low Ratio Break-in Rockers?? camaroman7d Engine 5 01-22-2004 04:16 PM
Synthetic for break in? What weight ? (engine and cam break in that is) sizemoremk Engine 5 08-14-2003 05:50 AM
Changing rings without pulling the engine? deleteall Engine 5 04-15-2003 08:28 PM
