Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Engine Breaking Stand Running Engine Test Stand
Old 04-04-2011, 02:52 PM
spinn's Avatar
spinn spinn is offline
Do it yourself. Grab some 4x4 and 2x4's , a 4pin GM module, mecahnical fuel pump, used flywheel, and connect starter. Start to box out the lower oil pan rail, support the back with a Tee peice. Connect the 4 PIN gm module for the ignition be it MOPAR Ford, or GM does not matter . The cooling system can be a radiator core with vacuum cleaner hose.
ID:	54206   Click image for larger version
