Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - engine build
Thread: engine build
Old 08-30-2009, 02:27 PM
BOBCRMAN@aol.com's Avatar
BOBCRMAN@aol.com BOBCRMAN@aol.com is offline
You will need to put a pressure gauge on the intake fuel fitting and compare to GM's spec. Even a couple of lbs. low will keep the engine from starting. Then its new pump time.
