Engine Build - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-16-2008, 12:04 AM
Chevyboy_0's Avatar
Diesel Fuel Abuser
Engine Build
Hey yall I'm new round here and had a few questions...
I have a 1970 Chevelle with a 350/350 Combo, The motor is the GMPP crate 290/350 HP. and after two years of questionable service the Rings have gone bad, also NINE months after I bought the Motor the Cam went flat(see where I'm goin?)
So now I plan to build my own motor, I have a solid block, and a good Set of Vortec heads, and I plan to build everything around that. I want to take the block out .030 over for a grand total of 355ci and run a 10:-10.5:1 CR and be able to spin it to 6000-6500 RPMS.
So my first question is, will the Comp Cams XR270hr grind cam work for the Vortecs? I have heard they will only take up to a .480 lift, will it be possible to machine them to work?
Also, are 882 or 824 heads anygood? and will either of these work for my build?
Thanks
Andrew
Old 04-16-2008, 07:23 AM
DoubleVision's Avatar
882 heads arent worth much, and no where close to a Vortec.
Any decent machine shop can clearence the valve guides so you can run your cam without issue, this is a common practice on vortec heads.
If this is a street engine, you will want to keep the compression in the 9:1 to 9.7:1 max unless you want to run race gas.
Old 04-16-2008, 09:58 AM
Chevyboy_0's Avatar
Diesel Fuel Abuser
Do the Vortecs need to have the Self adjusting rockers? I have Comp Cams Cam Quest and it has a foot note saying it needs a special part for Selfadjusting Arms. Can I change that or am I stuck with 'em
Old 04-16-2008, 10:07 AM
No you you can tap those heads and put in screw in studs and guideplates its much stronger anyway 10:1 or more is a little much for iron heads get a kit 9.5:1
Old 04-16-2008, 10:08 AM
If you run a roller you should run a 270HR magnum and have the heads machined for the bigger springs
Old 04-16-2008, 10:13 AM
Double_v23's Avatar
Horsepower Enthusiast
Last journal entry: Finished BMOD001FH
Yeah forget the 882's or 824's and go with the vortecs, you should be able to run 10:1 with those heads on premium gas. Flat top pistons with two small valve reliefs, decked to 0, and a decent .032 head gasket should bring you right into the range you need to achieve the 10:1. If you are going to be spending any time at all around 6500 rpm I would spend the extra money and get some nice 4340 forged rods, and make sure you have the entire assembly precision balanced and you should have a really nice setup. I also am a big fan of Gapless rings, so for an extra 100 bucks they are really worth it. Good Luck with the build, sounds like you are on the right track.
Old 04-16-2008, 10:33 AM
Chevyboy_0's Avatar
Diesel Fuel Abuser
does anyone have any ideas along the lines of pistons? I lke the Keith Black Claimer series, but I dunno how well they will work
Old 04-16-2008, 10:52 AM
they work great if you plan to keep high rpm use though for a long period of time id think of going to forged
Old 04-16-2008, 11:13 AM
Chevyboy_0's Avatar
Diesel Fuel Abuser
I'd like to get new heads but my friend is giving me heads and a block for free so I want to reuse those.
Old 04-16-2008, 11:22 AM
Chevyboy_0's Avatar
Diesel Fuel Abuser
Old 04-16-2008, 11:31 AM
Chevyboy_0's Avatar
Diesel Fuel Abuser
Thanks for everyones help and input. I'm only 18 and this is my first engine build.
By reusing the Rods what should I look for? I dunno how the rods are the motor spun a bearing, will I need to get new rods or just bearings?
Old 04-16-2008, 02:05 PM
Why is it everybody saves the best for last "the motor spun a bearing". This isn't just an aside event slightly worth the mention. A spun bearing means, depending on which bearing or bearings spun, the block is possibly damaged requiring expensive machine work to the main saddles and maybe replacement. Certainly the crank is damaged, not only on the journal of the spun bearing, but that junk circulates with the oil and has undoubtedly damaged other crank bearings and journals. If it was a rod bearing that spun, that rod is history and the others need to be looked at carefully by a trained eye for impending damage done to them as well. The cam bearings and cam journals probably also got a dose of chips.
The oil pump is probably toast, but the oil pump is the weak spot of the Vortec engine so getting that chunk of junk out of there is areal good idea. Minimalist oil pressure combined with energy saving oils and a bit of overheating and or a heavy foot are the cause of spun vortec bearings, which is a very common event.
I rather fear that this engine is likely to prove to be the proverbial Gift Horse, once you look in its mouth.
Bogie
Old 04-16-2008, 02:56 PM
Banned
Bogie
Or a spun bearing could just mean polishing the crank and getting a set of oversized bearings... which is the norm... and not a big deal at all...
Old 04-16-2008, 05:26 PM
Chevyboy_0's Avatar
Diesel Fuel Abuser
If that block won't work I have one, that was already rebuilt that sucked a valve, but this motor is already .040 over and I dunno how much more I can take the bores out
Old 04-17-2008, 12:06 AM
Chevyboy_0's Avatar
Diesel Fuel Abuser
Tonight i'm gonna buy a Scat 9000 series crank and forged Scat I-beam rods. What do people think of the Professional Products Hurricane intake for the Vortec Heads?
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 06:57 PM
1985 C-6 truck tranny, no engine braking effect fast68 Transmission - Rearend 40 02-04-2008 05:55 PM
350 engine build up heavychevy70 Introduce Yourself 2 01-27-2005 08:51 PM
first engine build 71chevellepa Engine 1 09-13-2003 04:30 PM
Engine build for hire,decision 78 monte Hotrodders' Lounge 9 05-10-2003 09:44 PM
