-   -   engine build (http://www.hotrodders.com/forum/engine-build-164230.html)
roadhogg 08-30-2009 12:55 PM
engine build
what up dudes,i have 1997 blazer 4.3 vortec wont start.it will run if i pour gas tnto the throttle body i change fuel filter and fuel reg. it getting fuel to the bleeder on the top of engine but still wont :nono:
BOBCRMAN@aol.com 08-30-2009 01:27 PM
You will need to put a pressure gauge on the intake fuel fitting and compare to GM's spec. Even a couple of lbs. low will keep the engine from starting. Then its new pump time.
