engine build - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-30-2009, 12:55 PM
engine build
what up dudes,i have 1997 blazer 4.3 vortec wont start.it will run if i pour gas tnto the throttle body i change fuel filter and fuel reg. it getting fuel to the bleeder on the top of engine but still wont
Old 08-30-2009, 01:27 PM
BOBCRMAN@aol.com's Avatar
You will need to put a pressure gauge on the intake fuel fitting and compare to GM's spec. Even a couple of lbs. low will keep the engine from starting. Then its new pump time.
Engine Build spec, how do you get yours Jsup Engine 13 12-21-2008 05:44 PM
Cadillac engine build bluesman423 Engine 6 09-05-2008 05:18 PM
engine build - 451 stroker Highway Engine 8 07-17-2008 10:39 AM
first engine build 71chevellepa Engine 1 09-13-2003 04:30 PM
Engine build for hire,decision 78 monte Hotrodders' Lounge 9 05-10-2003 09:44 PM
