engine build - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-06-2009, 01:29 PM
engine build
i have a small block chevy bored 40 over and it need a crank kit .a have the engine code from right side front behind the alternator that #is VO2250KB i need to know the year. and what cubic inch after bored
Old 09-06-2009, 01:42 PM
http://www.nastyz28.com/sbchevy/sblock.php
just scroll down and youll find exactly what you need.
your machine shop will be able to tell u how many cubes you're adding with a .040 bore
Old 09-06-2009, 01:45 PM
Those #s from the front of the block wont help you(i dont think). Look at the ones stamped on the pad that's near the distributor
Old 09-06-2009, 05:29 PM
techinspector1's Avatar
Wiki Edits: 326
That suffix code doesn't show up anywhere I looked. Give us the number off the back of the block, right behind where the rear of the intake manifold ends, on a shelf there, just before the rear face of the block on the driver's side.
Engine Build spec, how do you get yours Jsup Engine 13 12-21-2008 05:44 PM
Cadillac engine build bluesman423 Engine 6 09-05-2008 05:18 PM
engine build - 451 stroker Highway Engine 8 07-17-2008 10:39 AM
first engine build 71chevellepa Engine 1 09-13-2003 04:30 PM
Engine build for hire,decision 78 monte Hotrodders' Lounge 9 05-10-2003 09:44 PM
