We're winning the case!
Hotrodders Bulletin Board > Tech Help > Engine
  #1
Old 04-20-2004, 02:30 AM
Rug Rug is offline
Engine build ideas
Hello,
I am new to posting, but I have been reading here for a while. I live in Sweden and I am about to start a Cobra replica build.
I have come to the engine planing, and I can't really make up my mind. First off, there are some building rules to make this thing pass inspection when finnished. The car can not have more than 15kW of power per 10 kg of weight. This is only checked by engine number, so this means I would need a block from a car with roughly around (or less than 200 hp). This doesn't mean the engine will have 200 hp or less, it just needs the right engine number to pass... (I want more hp )
I would also like fuelinjection since that's all I've really worked with. This means I would need a fuelinjected engine to start with to get through inspections...
Now my thoughts... Start out with a TPI 350 block, add a Holley Stealth Ram with UltraMegaSquirt (should give plenty tunability). AFR 195cc heads would also be a nice touch. A tremec TKO and a Jag rearend will deliver the power to the ground.
Now to the questions. Should I build a 383 out if this thing? A reason for using fuelinjection is for future supercharger ideas. Maybe I should just save my $ from the 383 if I would like a supercharger? Money is of course a factor, but I would like to reach around 450 hp with a very streetable machine (decent idle, good cruising drivability, but with the possibility to rip your shirt off on weekends). I haven't decided how much the engine build budget would be yet.
Would 8.5:1 compression be ok do drive around with for a while before the supercharger is added? Build a 383 for supercharging application, but add the charger a year later? Or, build a good 350 and not wait a whole year for enough $ for the supercharger?
Carl W.
Old 04-20-2004, 07:57 AM
KULTULZ's Avatar
KULTULZ KULTULZ is offline
aka Duke of URL
KULTULZ's barnstar
Wiki editor
Last wiki edit: Finding vacuum leaks
Unhappy
Old 04-20-2004, 08:50 AM
Rug Rug is offline
Originally posted by KULTULZ
The only reason I would chose the TPI block would be to get around the regulations that you can not change a carbed motor to a fuelinjected motor. I am not planing to use the stock TPI intake or ECU. All I want from it is good strength and the engine number
As for TPI block strengt I don't know anything....
Carl
Old 12-14-2005, 04:47 PM
darrin26 darrin26 is offline
chevy motor in ford car
why a chevy? why not get a multiport 5.0 ford... or a 5.8? just about any 5.0 or 5.8 ford will be under 200 horse stock, and theyre cheap- i could buy a car with a 5.0 mpfi for under 500 dollars, aod and ford 8.8, or could go older and get a carbureted anything from the mid to late seventies that would be under 200 horse stock... and with carburetion you have a whole lot more options for performance- and with no knock sensors to worry about... bigger cam and such
Old 12-14-2005, 05:56 PM
Siggy_Freud's Avatar
Siggy_Freud Siggy_Freud is offline
Siggy_Freud's barnstar
Wiki editor
You wont find a stock TPI 350 that came with less than 200hp. The least was about 220-230.
If your not using the TPI setup, youd be better off looking for another block to start with.
1997 BMW M3 - 3.2litre Inline 6 cylinder
Old 12-14-2005, 06:22 PM
Centerline's Avatar
Centerline Centerline is offline
HotRodsAndHemis.com
Centerline's barnstar
Wiki editor
Last wiki edit: Streetbeasts fraud controversy
Wiki Edits: 38
Isn't it kind of like sacrilegious to put a Chevy engine in a Cobra, even if it is a replica? Forget the fuel injection and go with a 289-302 Ford small block.
Old 12-14-2005, 07:20 PM
NAIRB's Avatar
NAIRB NAIRB is offline
CHEVY CHEVY CHEVY CHEVY CHEVY CHEVY CHEVY CHEVY.
EVERYTHING IS CHEVY. SMALL BLOCK CHEVY ONLY!!! ON SALE NOW AT CHEVY SUPER SHOPS.
CHEVY POWERED STREET RODS CHEVY POWERED HEMI CARS CHEVY POWERED FORDS.
CHINESE CHEVY CHEVY CHEVY CHEVY. IF IT WON'T GO, CHEVY IT. SUPER CHEVY. CHEVY CHEVY CHEVY CHEVY CHEVY CHEVY CHEVY CHEVY CHEVY.
Old 12-14-2005, 09:36 PM
DHMag's Avatar
DHMag DHMag is offline
http://www.collectorcartraderonline.../0/80919160.htm
the engine is the Yamaha built 220hp/200ft lbs tq DOHC that came stock in the 1989-1995 Ford Taurus SHO. with a simple 6lbs of boost, you can easily break 300hp at the wheels. the stock intake manifold has a set of secondary runner butterflies that open at 3950RPM, giving what most call a BIG kick in the butt, power-wise. these motors redline at 7300RPM with accessories. without accessories, 9000RPM is doable on a stock bottom end.
forged crank with forged rods. i know an original owner and his SHO has over 300K miles and cylinder cross hatching is still evident. nickel content in block and low tension rings make it a very good combination.
Old 12-15-2005, 01:44 AM
xntrik's Avatar
xntrik xntrik is offline
Save a horse, Ride a Cowboy.
SHO would be great !! weight and handling !!!!
I say 5.0 Ford SFI..T-5 5 speed... start with a lo-po 160 h.p. from a big Crown-Vic if you have to for the regulations, and make it into an HO 225+ h.p. (stock 279 on the dynos) It could easily do 250 h.p. at the tires and look stock, have good smog, and get 30 miles per gallon.... 12 km per litre.
If you want a blower, go centrifugal (Vortec, etc) and get 375 at the tires easily.
That should be OK for 2000 pounds (910 kg).
www.readershotrods.com drag cars' georges drag strip
Size:  39.5 KB  Click image for larger version
Old 12-15-2005, 10:45 AM
red65mustang red65mustang is offline
At 450HP you have described a strong 350 drag strip motor, 3,000rpm+ power band
If you want occasional "tear your shirt off" just add a "on demand sniff" of nitrous (aka:"ricer racer" set up) to a mild build motor for idle/drive ability/mileage/etc, best way to have both
Chevy 350=575lbs.
Ford 5.0 =460 lb
learning carburation is easy enough, I would build it to "look" 289 vintage correct Shelby intake, valve covers, with the 5.0 HO
"got to have more...tear your shirt off"....make it a 5.0 347 cube stroker, trade mileage for power, still looks like a "tiny" 289
Old 12-15-2005, 11:02 AM
farna's Avatar
farna farna is offline
farna's barnstar
Wiki editor
Last wiki edit: Identifying AMC/Rambler Gen-1 V-8s and transmissions
Wiki Edits: 11
I think some people aren't catching "Sweden" and "regulations". If this were the US, things would be different! He needs a block that originally had fuel injection to use FI, and the serial number on the block needs to reference to a 200 hp or less original application. That's all the gov't is going to look at. It was already pointed out that a 350 Chevy TPI engine won't work, over 200 hp. I'm NOT a Chevy guru, but what about a TPI 305? A 305 is a smaller bore, but will accept the 383 stroker crank, correct? It wouldn't be a 383, it would only be 330 inches, but that would work within the gov't restrictions. With supercharging 400-450 hp should be attainable, plus the block can be bored for another 5" or so.
I have to admit though -- it's a Ford Cobra!! I don't know if "stroker" cranks are available for the 302 (5.0L), but it would be a nice engine for it. There was a 427 cammer in some of the Cobras, right? A 4.6L (or the larger one) wouldn't be quite the same, but would look nice!
Old 12-15-2005, 11:08 AM
Arrowhead's Avatar
Arrowhead Arrowhead is offline
EFI Rules and Carbs Drool
Arrowhead's barnstar
Wiki editor
Last wiki edit: The FREE T Bucket plans
Wiki Edits: 5
Nicely put NAIRB
How bout this?
Old 12-15-2005, 12:09 PM
farna,
you missed zntrik's comment (?): bolt in a "stock" fuel injected 5.0/160HP "taxi cab" motor to get past the inspection, then swap in HO parts (still looks like a taxi cab motor?)
yes 5.0 stroker kits are available, and since you mentioned it, a 5.0/331 stroker would be my choice
stock 89?-93? TBI 5.0's were listed "200"HP (yeah right, so how come they have 300ft/lbs stock)
Old 12-16-2005, 10:40 PM
xntrik's Avatar
Originally Posted by red65mustang
farna,
There were no TBIs in those years... we want an SFI.
Crown Vic/ Marquis/ Town Car 5.0 SFI were rated 160. The Mustang HO was up to 225. Cobra 245.
The blocks and intakes are the same. All that is different is, cam, forged pistons, truck heads, computer, and mass air on the later ones.
Make it a 342+ stroker if you want with AFR heads even a blower...
The HO cam has the W firing order. So what?
Old 12-17-2005, 08:33 AM
correction:89-93 60mm 5.0's were availble as 205HP motors....yes you can make them into a 245HP 93' motor....point was there are more 5.0' blocks to pick from.... close to 200hp stock
Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
