Engine build intake manifold choice
SBC 350 .040 over
Patroit 190cc heads CNC'd heads Comp cams xtreme energy 282 Hyd. Roller SRP Pistons Eagle crank and rods(I-beam) Crane gold roller rockers 670cfm holley carb MSD 6al I have a Professional products hurricane intake but my cam only makes power to 5800 RPM I planned on going with one of the air gap models (1500-6500RPM) Which do you guys favor? |
cant beat a performer rpm for street, been proven a gagillion times
manifold choice
The Professional Products Cyclone competes with the Edelbrock Performer. The Professional Products Typhoon competes with the Performer RPM and the Pro Products Crosswind is the equivalent of the Air Gap.
If you study the design of the Performer RPM and the Air Gap you will see that the design of the plenum and the runners are nearly identical. The only difference is the Air Gap has an open space under the plenum and runners. This is also true for the Professional Products Typhoon and Crosswind. The core used in the casting process, which is what is used to form the internal open spaces of the manifold (plenum and runners) is identical between these two manifolds. So typically the only performance difference that you will get is the open area under the plenum helps keep heat transferring from the engine to the manifold and the fact that outside air passes through this area also promotes a cooler air intake charge. I have never seen any direct comparison dyno tests but I would have to believe the the actual gain is fairly small. Probably in the range of 3 or 4 HP. |
| 350/290 GMPP Engine Build need advice(cam, intake etc) | Chevyboy_0 | Engine | 5 | 08-26-2010 12:32 PM |
| Manifold and engine build advice needed!!!! | off2wildblue | Engine | 25 | 07-16-2009 07:05 PM |
| First engine build - would a roller cam be a better choice? | surfshark | Engine | 4 | 05-28-2006 06:02 PM |
| Intake Manifold Choice? Please Help | sb72elcamino350 | Engine | 3 | 06-04-2005 05:58 PM |
| O2 sensor bung placement/ manifold choice | williambartram | Engine | 12 | 12-19-2004 12:31 PM |
