Engine Building Tools
What are the more finer engine building tools that any engine builder should have in his box. I'm trying to get a list together and maybe pick a few pieces up this week
Here is what I have so far Torque wrench Micrometers in metric Slide calipers Feeler gauges Degree wheel Ring pliers Ring compressor Is there anything else I should have? |
If you have a basic hand tool set , you're good to go.
You should also have.....a ring groove cleaning tool, a cylinder hone, a cylinder ridge reamer, and a valve spring compressor...just to name a few.
A good inside micrometer is a good thing to have too
Just wanted to heads up on these. Make sure you research and go for good ones. Cheap ridge reamer and valve spring compressor can cause nightmares. I have found a ball hone or dingle berry as some call it give better results then blade. Don’t forget a tap set , for cleaning threads to insure proper torque. |
And a cam bearing driver, oil pump primer, and perhaps a harmonic balancer puller/installer. The last just makes things easier.
3/8" drive swivel sockets, wobble extensions, spinner in 1/4, 3/8, and 1/2 inch drive. Bore gauge, gear puller, latex gloves or nitrile gloves if you are allergic to latex. Cylinder hone, both the aforementioned balls and one with stones. Bead blaster is nice to have for making clean parts. A workbench that no one else is allowed to use. Engine stand, not the 3 wheel type, but the 4 wheel type for stability. I made my own 4 wheeler with a solid bottom for catchpans or anything else. A thick clear platic sheet to cover your work. An inch-pound torque wrench.
I guess you can get building with all the tools mentioned here on this thread, but to try to list everything is really tough. I've got about $30K in tools from the last 24 years, not all for engine building but to try to name what I'd only use for engines is tough. Also, what type on engine are you building? If you are building a Ford 4.6L OHC then there is another bunch of specialized tools tht you will need. Post the type on engine that you are aiming to build. |
| Recent Garage - Tools posts with photos |
| Valve Lash adjustment | hiball | Engine | 36 | 05-11-2009 10:12 AM |
| need advice for building new engine for hot rod...... | Gino Fultano | Engine | 3 | 06-04-2004 08:04 PM |
| Whats a good Engine building (Assembling) Book? | Nos | Engine | 8 | 09-16-2003 02:08 PM |
| Anybody building an engine for HRM? | mustang66maniac | Engine | 7 | 05-18-2003 04:46 AM |
| Cam Help | black66 | Engine | 3 | 05-12-2003 06:15 PM |
