engine casting numbers - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-20-2006, 03:39 AM
62chevystepside's Avatar
New Member
Hello, I have been looking around the engine to see what year it is but the numbers i have found aren't in the mortec site. Its a small block chevy engine The numbers i have found are 8436572=drivers side cylinder head
8988920=passenger side cylinder
8486572= Intake beside firing order.
If someone could help me out I would be greatly apreciated, getting ready to buy new performance parts.
Thank you
,cody
or if i just post a picture up would you be able to tell what age it is, 70,80's
Old 02-20-2006, 04:31 AM
Monza Coupe Street/Strip
The 8436572 you found is part of the firing order. The casting number you need to determine what engine you have is on the right side of the block, rear, behind the cylinder head. The number faces upward, and is usually under a GM cast into the block.
Old 02-20-2006, 08:58 AM
DoubleVision's Avatar
3998920....72-73...350
This isn`t confirming anything though as this is just a cylinder head casting number, the block could still be anything since chevy parts interchange.
Old 02-20-2006, 01:11 PM
New Member
how do you look at the rear of the block when its in a car.
« cluj123 | 383 build »
crate chevy 302? Vancouver Grand Prix Hotrodders' Lounge 106 12-31-2012 05:05 PM
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 10:36 AM
Valve Lash adjustment hiball Engine 36 05-11-2009 11:12 AM
chevy v8 engine numbers Speed7 Engine 1 08-26-2005 08:34 AM
engine numbers ? andrewcdennis Engine 3 06-03-2002 09:36 PM
