Engine casting numbers and vin numbers - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-18-2010, 05:05 PM
Recently acquired a 81 Camaro Z28 accordinng to the vin. In reviewung the numbers on the block i became stumped. Looking for some help. Number at the left rear of the block ( casting number ) is GM 7 3970010. The number on the right front of the block is V0624TY7 TGF740229. The vin is 1G1AP87L4BN105993. Trying ti determine if the engine came with the car as well as what the specs are . Thanks in advance.
Old 06-18-2010, 05:13 PM
BOBCRMAN@aol.com's Avatar
If my geezer memory is correct. The 010 blocks ended around 78. When the dipstick was changed to passenger side..
Old 06-18-2010, 05:15 PM
Originally Posted by drfo
...V0624TY7
Are you sure it's "TY7"? Could it be TYT? The engine suffixes are in here...
http://www.chevy-camaro.com/chevy-ca...es.asp?group=6
If it's TYT, it's a '75 block.
The date code at the back of the block should be "F 24 5"
Old 06-18-2010, 05:27 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
79 was the last year for the 3970010.
Cole
Old 06-18-2010, 06:11 PM
Thanks
Dipstick is on the right side, I don't understand why their are two sets of numbers in the same area. V0624TY7 TGF40229. Any ideas.
Old 06-18-2010, 06:15 PM
Thanks
Thank you all very much. You have given me some great information. I don't understand the two (2) sets of numbers on the right front of the block. ( V0624TY7 TGF740229. Based on the info received, I can put to bed the thought that it was a number matching car. Have a great day.
Help with SBC casting numbers wickedtone83 Engine 4 02-02-2010 03:56 PM
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 10:36 AM
1968-1969 olds 455 engine is this good and how can i id 1968olds455HO Engine 5 09-02-2009 12:53 PM
Vin Numbers J.D General Rodding Tech 9 07-10-2008 04:24 PM
VIN and engine block numbers help please rakundig Engine 1 11-24-2003 06:01 PM
