Engine change - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-08-2002, 07:10 AM
Post Engine change
I may need a new engine and I would like to know if I can put a fuel injected enging in my 1985 Bronco with out to much trouble It has a 351 Winsor in it now and it has a automatic transmission.I wont to know if I could put a small block 302 in it and will it hook up to the trany.This is also a 4x4.
Old 01-08-2002, 07:56 PM
Post
No problem,Ford even makes a kit to upgrade to efi for your application.
Old 01-10-2002, 02:50 AM
Tom Tom is offline
Post
If you take the whole thing,engine,harness,computer,and fuelpump from the doner vehicle it will work fine
Old 01-10-2002, 07:44 PM
novass's Avatar
Post
It's not that hard a job. Much eaisier then many belive. Just make sure to get as much as you can from the doner.
Licensed CHEVY pilot, Certified car nut.
