I really don't know how to lay this out, but I'll try. I'm having to make a decision on an engine to put in a race car for a $5,000 to win dirt track race. The type of cars are Stock cars (75-81 Camaros, 75-79 Novas, and 78-86 Monte Carlos) that generally wiegh 3000 pounds. This class usually only pays $300 to win weekly, so I change classes all together, and then they come up with this race. The car I have from last year is a really fast car and had a great chance of winning under last years rules. Last years engine was a stock rotating assembly, Flat tops, 202/160 Vortecs, solid cam 355. It ran well against 6" rods, H beam rods, and light crank 355's. 366 cubic inch limit, no rollers, OEM heads, No Porting and Polishing were the rules. All i have left of that engine are the 1999 model Vortec Heads, Victor Jr intake, carb, and distributor. Here are this years rules.
BLOCKS – Cast iron only. Flat top or dish pistons only. NO Chevy 400 blocks
CAM AND VALVETRAIN – Any flat tappet cam OK. No mushroom, or roller of any type. No gear or belt driven cams. Screw in studs and guide plates OK. Roller rockers OK.
CYLINDER HEADS – Cast Iron only, OEM produced. No porting or polishing.
1). GM – straight plug only. Unaltered aftermarket cast iron, no porting, must add 60 lbs. in front of bell housing and car must weigh 3200 lbs.
As you can see, 383's, and 388's etc. are allowed. After Market unaltered Dart, Pro, and World Heads are allowed with a weight penalty. I need help with a engine combo that's not gonna break me.
#1. This is a $1,700 383 ci Short Block with stock rods:
• All Classic Series includes full balance
• 383 includes balancer and balance plate
• 383 include Scat cast steel crankshaft
• Fully prepped block ¬タᄁ Align honed ¬タᄁ Square decked with BHJ 90deg. fixture
• Race prepped rods with ARP bolts
• Speed-Pro hypereutectic pistons
• Performance moly rings
• Brass freeze plugs
• Screw in oil restrictors
• All JRM Shortblocks include engine stand
• Classic Series Shortblock include degree cam
• Clevite 77 rod & main bearings
• Completely clearanced and assembled
• Circle track camshaft
• Double roller timing chain set
• Cam lock plate and button
• Designed for racing use only
• No warranty
• Must be shipped by Truck Freight
#2. 355 ci with 6” rods I-beam for $2,300
• Align honed
• Square decked with BHJ 90deg. fixture
• Bushed 4130 Scat I-beam race prepped rods
• Scat cast steel crankshaft
• Pro-Tru forged pistons
• By Wiseco
• Stage 1 Shortblocks include degree cam
• ARP main bolts
• Performance plasma moly rings
• Clevite 77 rod and main bearings
• Circle Track camshaft
• True roller timing chain set
• Balanced
• Deck plate honed
• #3. This is a 355 ci for $3,300 with 6” H-Beam rods and 4340 crank
• Align honed
• 4340 race prepped H-beam rods
• 4340 Scat Crankshaft
• by Wiseco
• ARP main studs
• Stage 2 Shortblocks include degree cam
• Dura-bond HP cam bearings
• Clevite 77 H-Series rod and main bearings
• Internally balanced
• Deck plate honed
So I have 3 engine choices with 3 engine prices. I'm not really worried about which one has parts that are supposed to hold up longer, just which one produces the power. There's one 383 with 5.7 rods vs. two 355's with 6" rods and forged pistons. On the 355's? Will the 4340 crank ,and H-beam rods make more horsepower than the I-beam rod, 4140 crank engine. If so, how much? I'm assuming the price difference is coming from the rod and crank difference. I really wanna stay way from the one that cost $3,300(H-beam, 4340 crank), but will the $2,200 keep up with it(I-Beam, 4140 crank). If so, it would be the 6" 355 vs. the 5.7 383, and the rest of their differences(Rods, Crank, Pistons, etc.).
These cars tires aren't that great, and they have no traction devices. Some of the guys who have cheated in the past with 406's, said it did them no good because they couldn't get the traction they needed. I've heard the extra torque that comes with a 383 vs. the 355 is a little harder to hook up on dirt.
Back to the heads, will the 202/160 Vortecs do as well as a set of DART, Pro, or World Heads. Remember with those heads there is a weight penalty, and they have to be unaltered. Is it worth it to buy them if I already have a set of Vortecs.
$1,700 383
$2,300 355
$3,300 355
Free Vortecs
64cc World 200cc $750
64cc Dart 200cc $800
64cc Pro 200cc $750
If you read this, thank you, I need your help.
• No warranty
• Align honed
• By Wiseco
• ARP main bolts
• Balanced
• Deck plate honed
• Align honed
• by Wiseco
• ARP main studs
• Deck plate honed
$1,700 383
$2,300 355
$3,300 355
Free Vortecs
64cc Pro 200cc $750
