Engine cleaner - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-05-2007, 02:18 PM
strummin67's Avatar
Violating consensual reality
Last journal entry: It tows!
Engine cleaner
What's a good engine cleaner to use with aluminum? I just found out the hard way that I used a cleaner I shouldn't have. What took probably 20+ hours to clean and polish just "sprayed" off in 10 seconds.
Old 05-05-2007, 04:40 PM
larryblack's Avatar
Certified Lead Foot
You have to watch as most aluminum cleaners are an acid etching cleaner. I have used ESPREE wheel cleaner on polished aluminum valve covers but they dulled some. It did remove the grease and oil nicely, but I put some time on the buffer to get the shine back.
Old 05-06-2007, 08:53 AM
I use a product called "Sea Wash", but you don't want to let it soak long enough to allow any drying on aluminum. I spray it on and let it soak about as long as it takes me to crank up the pressure washer for the tough spots. If it is a relatively clean motor, I just turn the water hose on it. I do use this on my wheels as well and it is a good tire cleaner also.
Trees
crate chevy 302? Vancouver Grand Prix Hotrodders' Lounge 106 12-31-2012 05:05 PM
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 07:57 PM
Trouble trying to start engine for the first time. Z-Money Pit Engine 8 10-29-2009 10:02 PM
1973 Chevelle Malibu Engine Rebuild (pics 56k no) Malibu73 Hotrodders' Lounge 39 11-04-2008 01:37 PM
pontiac engine noise, possibly rod knock? Blob Engine 4 08-06-2006 03:01 PM
