Engine code - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-02-2013, 08:57 AM
Engine code
Engine block codes:
T10I8HF
18R116158
I have look everywhere to translate these codes. Can someone please help me? Thanks.
Old 10-02-2013, 09:51 AM
techinspector1's Avatar
Wiki Edits: 326
The motor was produced in the Tonawanda plant on October 18. The "HF" code was used on at least 4 different motors, so scroll down on this list and see HF....it's either a 327 or a 350.
Decoding small block Chevy engine suffix codes and stamped numbers DTR - HQ
We would need the casting number off the motor. It's on the narrow shelf that forms the bellhousing mating surface at the back of the motor on the driver's side. If the motor is in the vehicle, you may have to use a strong flashlight and a mechanic's mirror to see it. If the motor is out of the car, walk up to it and look down at the rear of the block just before the bellhousing mating surface. Also, you'll want to pull a valve cover and give us the casting number off the cylinder head. It's in between the springs/valves right on top.
Old 10-03-2013, 06:13 AM
techinspector1:
I have the engine out of the truck now and starting to tear it down a bit. I did find out that it is a 327 from 1968. The heads are from a 350 (3986338x). I plan on rebuilding this engine to get over 300hp but nothing for racing. Just something to take to shows and drive on Sundays. I have a Powerglide transmission that will be going back into it. I have ordered my headers from summit racing (HOK-2131-3HKR Headers, Super Competition, Full-Length, Steel, Black Ceramic Coated, Chevy, Small Block).
NOw I am looking for the best combination of crankshaft, pistons, camshaft, instake, heads, lifters and etc. I do not plan on bored this engine out. Thank you for your time.
Old 10-03-2013, 09:35 AM
Wiki Edits: 326
If you don't have the tools and expertise to measure the cylinder bores for being egg-shaped or tapered, haul the block into an automotive machine shop and have them do it for you. If the bores are round and straight, match the honing stone and honing procedure to the ring material and design. If the bores are egg-shaped and/or tapered, you have little choice but to bore and hone for oversized pistons and rings.
engine code booberloc Engine 2 07-19-2011 09:27 PM
GM Engine Code bscooter Engine 8 12-11-2010 07:54 PM
Help with Engine Code doug66762 Engine 13 12-27-2009 06:14 PM
Gm Engine code elcamino53 Engine 6 09-08-2009 07:44 AM
engine id code cdn tpi engine sanders20052 Engine 0 11-04-2005 07:57 AM
