engine code confusion
i have an engine with the casting number of 3959532, there are two lines of numbers stamped on the pad in front of the r/h head that read CE6N251 and under that number is the So824XO number any idea on how to decipher would be appreciated
The CE designates it as a crate engine.
Horsepower is how fast you hit the wall. Torque is how far you take the wall with you. Midnight Sun Street Rod Association |
i have looked at the site and sort of confused:the casting number says it is a 69 283 block but the numbers on the landing indicate it is a ce crate engine the next number being a 4 i am assuming it is a 74 since ce was not used till 1968 now the rset of the number says it is a saginaw built engine in aug and that it is a 350 truck engine. Do they use the 283 block to build 350 truck crate engines?that i guess is the question
That code is a 1956-67 283 number. A 283 would take a .125 overbore to make a 350, not impossible but not doable on all 283's, the main bearing size of a 283 is smaller than a 350 also.
You might need to check the bore and stroke. |
| 292 engine code | John Chesal | Engine | 3 | 11-14-2010 10:20 AM |
| Engine ID Confusion! | 71vellelover | Engine | 9 | 10-11-2010 05:57 AM |
| engine confusion | kevin35 | Engine | 6 | 01-24-2006 12:52 AM |
| Need help with this engine code.. | WillT | Engine | 3 | 04-29-2005 03:39 PM |
| engine code | rustyrazer | Engine | 0 | 05-13-2003 03:09 PM |
