Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - engine codes
Thread: engine codes
Old 01-18-2013, 11:12 AM
Mr. P-Body Mr. P-Body is offline
Bill knows Pontiacs. So do I. We've both told the OP the same thing. The partial VIN on the block is meaningless regarding ID of the ENGINE.
To correctly identify a Pontiac you need: Engine code (2 digits, alpha-numeric, stamped on the front of the block NEAR the partial VIN); date code (by the distributor) and block casting number (on bellhousing flange), both CAST "in". That's IT.
Relax. It isnt that complicated... (:-
Jim
