Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - engine codes
Thread: engine codes
Old 01-18-2013, 02:47 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Guys, unless I miss my guess, Eddy's asking about two Chevy small blocks. (HC and TPA are Chevy suffix codes.)
Originally Posted by eddybugn View Post
Can you tell me what these engines are and from. One has this number F03I7HC and the other is V0320TPA. Thanks in advance.
The best site for suffix codes (chevymania) is down again. But I recall TPA is a 350 sbc truck engine suffix (could be a 4-bolt main)- although there can be other engines that use the same suffix code- like all the different engines that use HC. That's why you need the date code and block casting numbers to tie it all together to one application. More info on ID'ing your engine is here.
If you have more questions, just start a fresh thread. And welcome to Hotrodders.
The Following User Says Thank You to cobalt327 For This Useful Post:
eddybugn (01-18-2013)
