-   -   engine codes (http://www.hotrodders.com/forum/engine-codes-164240.html)
66chevynova 08-30-2009 03:26 PM
engine codes
Can anyone help me figure this code on this motor? it is mk07800. I can't find anything about it. I would like to rebuild it and would like to know alittle bit about it. Thanks ,Galen
DoubleVision 08-30-2009 06:53 PM
I`m guessing this is a small block chevy? If so the M indicates GM of mexico. What`s the casting number? Does the block have Hencho en mexico on it?
ericnova72 08-30-2009 07:05 PM
Sounds typical of a Targetmaster crate replacement engine #.
66chevynova 08-31-2009 04:15 PM
Doublevision It is a chevy motor and I did recheck it and it does have Hecho en Mexico on it. The casting # is 3970010. I'm trying to find out what the horse power is.
DoubleVision 08-31-2009 05:58 PM
As Eric said, it`s a target master engine. It didn`t come with much power. It has large chamber smogger heads on it and dirt low compression ratio.
These engines weren`t made with performance in mind. But you can use it to build power if you wish.
fast68 08-31-2009 09:00 PM
just a replacement common mexican crate 350
not great castings quality,,..,,. but if it runs then thats a good thing
