engine codes - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-30-2009, 04:26 PM
engine codes
Can anyone help me figure this code on this motor? it is mk07800. I can't find anything about it. I would like to rebuild it and would like to know alittle bit about it. Thanks ,Galen
Old 08-30-2009, 07:53 PM
DoubleVision's Avatar
I`m guessing this is a small block chevy? If so the M indicates GM of mexico. What`s the casting number? Does the block have Hencho en mexico on it?
Old 08-30-2009, 08:05 PM
ericnova72's Avatar
More for Less Racer
Sounds typical of a Targetmaster crate replacement engine #.
Old 08-31-2009, 05:15 PM
Doublevision It is a chevy motor and I did recheck it and it does have Hecho en Mexico on it. The casting # is 3970010. I'm trying to find out what the horse power is.
Old 08-31-2009, 06:58 PM
As Eric said, it`s a target master engine. It didn`t come with much power. It has large chamber smogger heads on it and dirt low compression ratio.
These engines weren`t made with performance in mind. But you can use it to build power if you wish.
Old 08-31-2009, 10:00 PM
fast68's Avatar
likes chevy trucks & boobies
just a replacement common mexican crate 350
not great castings quality,,..,,. but if it runs then thats a good thing
GM 5.7L crate engine suffix codes SCRUBBY Engine 2 11-30-2009 05:36 PM
SF oil???? n-gin Engine 6 07-09-2008 02:37 PM
Block Engine Codes HELP???? Twin Camaro's Introduce Yourself 4 03-28-2008 09:37 PM
Whats the correct temperature my 350 should be running at? batman09 Engine 101 10-23-2005 01:29 PM
My 305=C8L...can't find it on chev engine codes list frankthetank Engine 0 10-27-2003 10:09 PM
