Engine Combo 355 Help - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-12-2008, 05:51 PM
Alright heres my combo tell me your thoughts good, bad, or ugly!
1972 350 bored to a 355
comp cams 292 292 .501 lift
eldabrock victor jr intake
holley 750
Hei ignition
double roller chain
1 3/4 inch hooker super comps (open headers)
Kills torque I know guys I know but it sounds so good!
and the dead blow to my combo
BASICALLY STOCK HEADS
74cc chambers
1.94 intake cant remember the exhaust but its a stock valve thinkin 1.5
I fired it up and it runs good, ant drove it yet no insurance, but it revs fairly quickly, horse power guess please!
the heads i know the heads it all takes $$$$$$$$$$$$
Old 08-12-2008, 05:53 PM
over cammed, low-ish compression engine
Old 08-12-2008, 05:57 PM
I figured any guess on the cr i like the cam any suggesions on what to change next to fix the problem
Old 08-12-2008, 07:50 PM
Rubberman2003's Avatar
8 or 8.5:1 ? Good set of heads, at least i would replace those stockers. What is the casting number on them?
Old 08-12-2008, 11:20 PM
techinspector1's Avatar
Wiki Edits: 326
Pull all the plugs, disconnect the coil, wire the throttle blades open and do a compression test on all cylinders. SURPRISE!!!
Old 08-13-2008, 04:44 PM
The site I used said they were 76cc chambers off a 350 or 400 they were used on both engines I guess. Didnt find anything on the flow numbers. Let me know if you can find it or know off the top of your head. Any hp guesses. Maybe with a set of heads? What about a set of camel hump or vortech heads off a newer block.
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 50 01-12-2011 10:00 PM
Is this a good prostreet engine combo? lt1_performance Engine 1 01-01-2008 08:37 PM
Anything wrong with this engine combo?? Scott2112 Engine 6 03-05-2007 09:53 PM
Need help choosing a gear to match my engine combo. Super Chevy Engine 5 03-22-2006 08:09 PM
second guessing my r.e./ trans./ engine combo. jcarter Transmission - Rearend 7 04-13-2004 02:15 AM
