We're winning the case!
Hotrodders Bulletin Board > Tech Help > Engine
  #1
Old 10-17-2009, 08:11 AM
skybu skybu is offline
Engine combo question "DCR"
L31 short block with 64cc aluminum heads is supposed to be 9.4-1 compression.
Hydraulic roller cam with 224 intake,230 exhaust duration @ .050 with 110 lobe separation.
I was wondering if the dynamic compression ratio was going to be to low on this motor to perform well, if so I will go down a notch on the cam selection.
Also....I want to be able to run 87 octane.
Old 10-17-2009, 06:42 PM
more cam specs...
intake centerline-106
valve timing @ .006 lift 64 degrees ABDC
Old 10-18-2009, 07:02 AM
SSedan64's Avatar
SSedan64 SSedan64 is online now
JackOfAllTradesMasterOfNo ne
Compression calculators here. >> http://www.kb-silvolite.com/calc.php
Old 10-18-2009, 08:54 AM
NXS's Avatar
NXS NXS is offline
That cam is perfect, don't look to change anything...except maybe put some thinner gaskets on it IF you don't already have the heads on...
Old 10-18-2009, 06:17 PM
Thanks man.... the 9.4:1 is going to have to stick though. I dont think I can do much better anyway because that is with the GM .028 gasket. My gas is pretty bad around here anyway.
I have also been toying around with the idea of going with 112 lobe separation instead of 110 to spread the power band out a bit and make it idle a little better.
do you guys have an opinion ?
Old 10-18-2009, 06:24 PM
formerice formerice is offline
I think it will run just fine. Still I would try to tune it for the best gas that you have. 91 octane should give you a little boost.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "Engine combo question "DCR""
SF oil???? n-gin Engine 6 07-09-2008 01:37 PM
say you have a THOUSAND horsepower engine..... (technical engine question inside) lowROLLERchevy Engine 14 02-24-2007 08:26 AM
supercharger.... 73monte Engine 10 07-31-2006 09:38 PM
Hotrodders Guidelines -- READ ME Jon Hotrodders' Lounge 0 06-14-2003 05:08 PM
Hotrodders Guidelines -- READ ME Jon Hotrodders Knowledge Base 0 06-14-2003 05:08 PM
