-   -   engine combo...thoughts? (http://www.hotrodders.com/forum/engine-combo-thoughts-19384.html)
redcamaro4spd 07-11-2003 10:00 PM
okay, so I know yo are all getting tired of me asking about the 350 I am building. So I thought I would post my specs at this point and see what you all had to say. Hopefully, soon I won't be needing advice setting it up as it will be dropped into the car. Okay, here goes:
1986 350 (4 bolt main)
Bored .030 over
Summit Engine Rebuild Kit with:
-Sterliong Pro pistons at .275 inch dome to produce 10.26 to 1 comp.
-high volume oil pump
-fed. mogul bearings
-fel pro gaskets
Other specs:
462624 heads with 1.94/1.50 valves and 76cc chambers
Comp Cams 268XE with .477/.480 lift (cam and lifter kit)
Edelbrock Performer Intake
Edelbrock 600cfm Carb
Dynomax headers into 2.5" dual exhaust
Stock crack, rods, rockers, HEI dist., and accessories
I think thats it, if I forgot something lemme know and I'll post specs. I hope to run on 93 octane pump gas. Please let me know what you think. BTW I know my heads are cruddy, but they'll have to do for now...Thanks again folks...
akm 07-11-2003 10:15 PM
trans?
redcamaro4spd 07-11-2003 10:28 PM
Super t10 coupled withan open 3.73 rear (currently 2.73, but will be switched soon)
redcamaro4spd 07-12-2003 02:57 PM
sorry, but need to bump for weekend crowd
