engine compartment - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-03-2004, 06:04 PM
jaxon's Avatar
engine compartment
I have purchased a chevy small block and looking for info on the numbers on the block to see what ive got
Old 06-03-2004, 06:06 PM
You've got a chevy SB, whats the bore? That will tell you right there.
Also this should be in the engine section!
Old 06-04-2004, 06:11 AM
M&M CUSTOM's Avatar
Wiki Edits: 9
HMMM!! I don't think so.
A few different small blocks shared the same size bores, but had different stroke cranks, that is as accurate as guessing.
262 = 3.671" x 3.10" (Gen. I, 5.7" rod)
265 = 3.750" x 3.00" ('55-'57 Gen.I, 5.7" rod)
265 = 3.750" x 3.00" ('94-'96 Gen.II, 4.3 liter V-8 "L99", 5.94" rod)
267 = 3.500" x 3.48" (Gen.I, 5.7" rod)
283 = 3.875" x 3.00" (Gen.I, 5.7" rod)
293 = 3.780" x 3.27" ('99-later, Gen.III, "LR4" 4.8 Liter Vortec, 6.278" rod)
302 = 4.000" x 3.00" (Gen.I, 5.7" rod)
305 = 3.740" x 3.48" (Gen.I, 5.7" rod)
307 = 3.875" x 3.25" (Gen.I, 5.7" rod)
325 = 3.780" x 3.622" ('99-later, Gen.III, "LM7" 5.3 Liter Vortec, 6.098" rod)
327 = 4.000" x 3.25" (Gen.I, 5.7" rod)
346 = 3.900" x 3.622" ('97-later, Gen.III, "LS1", 6.098" rod)
350 = 4.000" x 3.48" (Gen.I, 5.7" rod)
350 = 4.000" x 3.48" ('96-'01, Gen. I, Vortec, 5.7" rod)
350 = 3.900" x 3.66" ('89-'95, "LT5", in "ZR1" Corvette 32-valve DOHC, 5.74" rod)
364 = 4.000" x 3.622" ('99-later, Gen.III, "LQ4" 6.0 Liter Vortec, 6.098" rod)
383 = 4.000" x 3.80" ('00, "HT 383", Gen.I truck crate motor) (5.7" rod)
400 = 4.125" x 3.75" (Gen.I, 5.565" rod)
Old 06-04-2004, 07:16 AM
Weimer's Avatar
Kenneth Howard hates you...
Last journal entry: door pics smaller
Re: engine compartment
Post the casting #'s here....I am sure one of us can decode it for you.
Later,
WEIMER
