engine compartment insulation - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-28-2005, 10:03 AM
I was looking to find a good material to prevent heat migration into the passenger compartment,any suggestions, I had been told that some have used a water based roof coating material with ceramic particals to basically eliminate radiant heat transmission and it also works as a sound deadener. Has anyone tied this ? I have used the foil blanket material works pretty well but pretty hard to keep it looking nice. Thanks
Old 03-28-2005, 12:43 PM
solidaxel's Avatar
Last journal entry: Project garage complete!
Just start at one side and fill the ones you don't need !!!!
Name:	photo (1) Copy (6).jpg
ID:	4413   Click image for larger version
Old 03-28-2005, 01:14 PM
Tazz
Call around...
maybe even talk to the interior guys about the silver covered product that sticks to the floor under the carpet to sound deaden and keep the heat out of your passenger compartment. Don't know exactly what its called but have seen it for sale. It is a silver foil sandwiched over a sound deadening product that you can glue to the firewall and floor inside your passenger compartment. They also use it in on the floors of racecars to keep the exhaust heat out of the passengers compartment.
Tazz
Rat Rods Rule!
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 50 01-12-2011 10:00 PM
Valve Lash adjustment hiball Engine 36 05-11-2009 10:12 AM
Engine Compartment room? offroadin Engine 6 02-23-2004 07:14 PM
engine compartment panel replacement 67stang Body - Exterior 3 01-20-2003 05:01 AM
Engine Compartment Liner Mike Fryer Body - Exterior 1 10-21-2002 06:21 AM
