Engine coolant goes missing? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-10-2012, 10:12 PM
Hey guys,
A few weeks ago, I went to check all the fluids in my car and i noticed the coolant was low. So I bought some coolant (50/50) and poured it in. Then I just checked it today and noticed it was almost half empty again. So filled the reservoir and radiator. Why is this happening? Is this due to a bad head? The car s exhaust does not splurge out white exhaust or anything either. There is absolutely no leak that I can see coming from the car.
Old 04-10-2012, 10:42 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by 79bird
Hey guys,
If the head gasket is leaking coolant into a cylinder, that cylinder's plug will look quite different from the others. Pull the plugs and take a look.
If the radiator has a pinhole leak you can lose coolant over time and never see a leak on the ground. Does the oil look normal- not cloudy or frothy?
Did you recently drain and refill the cooling system?
Old 04-10-2012, 11:11 PM
No I Have not, Ive only added coolant fluid to it
Old 04-10-2012, 11:23 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
I'd suggest throwing a sheet of cardboard under it over night to see if it's an external leak. It will also give an general idea of where the leak is coming from.
It's quite common for coolant to leak from the weep hole on the water pump ... a sign that the impeller shaft seal and/or bearing may be on their way out.
Any antifreeze smell on the interior of the vehicle, or mist on the windshield above the defroster ducts on the dash? Small puddle of antifreeze on the carpet or drips hanging from the ductwork? Those are signs of a deteriorating heater core.
It may even be as simple as a bad radiator cap. Does the car have a recovery tank or coolant reservoir on it?
Edit: re-read and discovered that you do. Check the reservoir itself as well.
Get the cap and cooling system pressure checked. That leak will show up under pressure.
Good luck.
Old 04-10-2012, 11:27 PM
Good luck.
Thanks, well what happened was the coolant resevoir was empty from the day i bought the car until today. Could this be the problem?
Engine is missing, help! durand322 Engine 7 05-20-2010 12:22 PM
Coolant Dilemma! Ok to use Green coolant with Red coolant? mgold Hotrodding Basics 6 03-31-2009 04:37 PM
My engine feels like its missing Camaro31 Engine 9 09-30-2008 01:27 AM
Engine Missing 59fordf100 Engine 6 04-19-2005 09:34 PM
Mallory VI-AL and engine missing Meangreen Engine 6 05-29-2004 01:57 PM
