engine diaper on 10 second Model A - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-17-2013, 11:39 PM
471A
After years of trying, I finally got my Tudor A streetrod to run in the high 10s in the quarter. The bad news is that now, NHRA requires any car running under 11.00 to run an engine diaper. For reasons of over heating, it is not practical to run an engine diaper on a street rod. And "Yes", I could slow the A down, most easily by swapping the upper pulley on the 4/71 blower, but after all these years, literally decades, of getting a street ride into the 10s, I do not want to go there. Any ideas out there on making an engine diaper work on a street rod ? It simply is too much fun to have a grocery getter that will run high 10s in the quarter, then drive home from the track on street tires.
Old 05-18-2013, 12:54 PM
WDCreech's Avatar
Grumpy Old Goat Herder
In the NHRA rulebook, under General Regulations, 1:8 refers to engine containment. It states that you can use a belly pan with a flameproof absorbant pad installed. I use small binder clips to hold the pad in place.
Bill
The Following User Says Thank You to WDCreech For This Useful Post:
AutoGear (05-24-2013)
Old 05-18-2013, 02:57 PM
techinspector1's Avatar
Wiki Edits: 326
As Bill says, you can use a sheet-metal tray with 2" high sides, sort of like a pan you might use on the garage floor to catch drips.
"..... may use a belly pan in lieu of a
device attached to the engine. The belly pan must extend from
framerail to framerail and extend forward of the harmonic balancer
and rearward to rear engine plate and must incorporate a minimum
2-inch-high lip on all sides. A nonflammable, oil-absorbent liner
mandatory inside of retention device. Minimum number of slots or holes in the walls to clear frame, steering, or lines permitted."
Oil Absorbent Mats: Find Oil-Only Absorbing Pig Mat & Pads | New Pig
I would bend up a tray at a sheet metal shop after measuring the size needed. Much trial fitting will be necessary to determine where straps and such will be welded on to mount the tray to existing points on the car. I'd use oil-absorbent pig mat in the tray, covered with a piece of expanded metal to prevent the pig mat blowing out of the tray at speed. Secure the expanded metal to the tray.
The Following 3 Users Say Thank You to techinspector1 For This Useful Post:
AutoGear (05-24-2013), BigMo (06-10-2013), dinger (05-24-2013)
Old 06-10-2013, 02:26 PM
BigMo's Avatar
Great idea, Im in the middle of reworking a similar car, except a Coupe, and will be in the 10-sec range also if all goes right
Any way to tell what year and model an engine was taken from? Torque454 Hotrodding Basics 2 03-14-2013 12:06 AM
engine model rosgood14 Engine 3 08-24-2010 04:02 PM
Ford 32 Model B Engine Specs Rogers Performance Engine 3 05-03-2007 06:14 PM
BMW M3 engine, eu model Duke of Cruel Engine 1 10-24-2006 01:55 PM
Engine location in Model A deathbypontiac General Rodding Tech 10 12-14-2005 11:54 AM
