Engine Died, Lost Fuel Pressure - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-19-2005, 03:52 PM
edge's Avatar
Time is short, are you ready?
I am writing this thread for the purpose of documenting a problem I recently had and wanted to share the cause so that anyone searching may find this information useful.
As many already know, I converted my 1994 Suburban over to TPI (Click here for Details). When doing this, I installed a 1991 GTA high pressure in-tank fuel pump in place of the stock TBI low pressure pump. Apparantely, I inadvertently re-installed the short lenght of low pressure hose. In less than one year and approximately 15k miles, it split the side and therefore, I lost nearly all fuel pressure at the rails.
I knew it was either a pump or in-tank hose problem when I manually crimped the return line and could only get about 10 psi of pressure. A normal TPI pressure is 40+ psi.
I went ahead and installed a new AC Delco pump, strainer and the section of hose that came with the pump. Click here for the link and below are a few pictures. Ed
Old 04-19-2005, 05:36 PM
Siggy_Freud's Avatar
Good to know. I dont imagine that many people would think fuel line/hose failure when it comes to a problem like that.
Bringing history and technology together.
Valve Lash adjustment hiball Engine 36 05-11-2009 11:12 AM
Fuel pressure drops when electric fan turns on Palmtrees57 Engine 3 09-04-2004 02:12 PM
Fuel Pressure is Dropping !!!! HELP!!! juveteach Engine 3 07-01-2003 02:57 PM
Measuring Fuel Pressure Waterhead Engine 7 06-20-2003 09:39 PM
Cam Help black66 Engine 3 05-12-2003 07:15 PM
