engine dies or stubbles after i blip the throttle
tell me what you guys think. 350 with 305 heads stock cam and crappy exhaust. the only carb i have to put on it is a 750 vac. secondary (i know thats to big but its all i got) i rebuilt the carb myself i put 72 jets in it and lowered the float level down a hair below the site hole and the motor seems to run pretty well. i set the mixture screws with a vacuum gauge and i think there pretty accurate. the timing is set at 8 degrees btdc and the idle is set at 800 rpm. the problem im having is if i put it in gear and blip the throttle with my foot on the brake the the tires chirp/spin but then upon deceleration the motor stubbles real bad and dies. any ideas? idle to low? floats? squirters?
