Check the alignment of your neutral safety switch.......It is either in the console, on the trans or under the steering column.......If my old memory is right, yours is under the column
Ontario Rodders |
Often it's the adjustment of the neutral switch. Check it by (safely in the driveway) putting the shifter in "N", and then trying the key. From there, try moving the shifter fore and aft a little from "N" as you try the key- if it's a little out of adjustment, this will cause it to try to start.
Keep your foot firmly on the brake in case it starts and is in gear. |
Ontario Rodders |
Hello again,
The switch i working, it is just misaligned. I made some tests as cobalt327 suggested. I should put the shifter almost on D in order to start the engine. How can I adjust this? Thanks for the help Ivo |
With this linkage back in adjustment (it gets worn over time), the column lock out will allow starting in N or P w/o drama. IIRC, there will be a lock bolt that holds the linkage going to the end of the column. Loosen this bolt and pull the linkage to remove any slack and retighten, this is all w/the shifter and tranny in "P". |
Isn't the whole PURPOSE of a neutral safety switch to NOT allow the car to start in neutral?
Ontario Rodders |
DUH! I knew that. My brain must have been in neutral!!!
| How Does A Thermostat Work? | cobalt327 | Hotrodding Basics | 16 | 03-16-2010 06:32 AM |
| Buick 430 Engine | 70LEBUICK | Engine | 5 | 02-24-2010 09:57 PM |
| Valve Lash adjustment | hiball | Engine | 36 | 05-11-2009 10:12 AM |
| Oldsmobile 3.8 engine won't start | oldchevy1956 | Engine | 5 | 06-05-2008 05:58 AM |
| Engine start up | rock141b | Hotrodding Basics | 1 | 05-13-2004 12:52 AM |
