Engine dyno sheet, timing? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-27-2006, 11:41 PM
New Member
i was looking at my engine dyno sheet and it says 32* but where do i set that at what rpm? its a 383 408hp 433 torq
Old 08-28-2006, 07:50 AM
What we do in our dyno cell, and every other dyno cell we have worked in is check and set total at 3000 RPM for a street motor.
Old 08-29-2006, 12:15 PM
New Member
so lock in 32* at 3000rpm anything else i should be doing or watching for thanks.
Old 08-29-2006, 01:37 PM
Then verify that the base timing at idle set point is reasonable, like in the 10-12 range. If it's not your going to have to have the distributor recurved, either with bushings or weights, depending on the distributor. You also want to make sure that at idle speed the timing setpoint is pretty rock stable, no wavering or wide fluttering.
Vacuum advance hooked up directly to manifold....is this bad????? Steve-0321 Engine 69 03-10-2014 06:10 PM
Port or Full time vacuum cool rockin daddy Engine 129 10-05-2010 04:00 PM
Dyno engine with a blower anyone? HemmiGremmie Engine 14 07-06-2005 07:07 AM
Cam Help black66 Engine 3 05-12-2003 07:15 PM
Ingnition timing for engine start up 77Cobra Engine 0 05-10-2003 01:06 AM
