Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - engine and ECM swap
Old 02-10-2013, 05:07 AM
dstanford60 dstanford60 is offline
which one to use
you say I might have issues with the check engine light coming on all the time because there is no 4L60 tranny,and I might be able to get the ECM program to run as a stand alone,is it possible that I might be able to use the ecm to run a 700R4 instead of the 4l60 if I use the DRAC module for the vss and use the E10 wire from the ecm(the TCC sol. wire) to lock the converter,how do you think this will work,I am trying to use the 16168625 ecm to control the 5.7 and the 700R4,I know the ecm is design for a 4L60 but will it run the 700R4
