Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - engine and ECM swap
Old 02-11-2013, 02:39 AM
dstanford60 dstanford60 is offline
ok then that is what I will do,I will run the 7727 and save me a lot of head ache's I already have the vacume switch,and the brake switch,but don't I have to use the P/N switch also,and I was wondering if the buffer from the 93 would work on the 700,its a DRAC,the one from the 93,if not I will go to pick a part and pull the dash out of another vehicle and get on,so I guess monday evening I will put the wiring harness I put together on it,thanks again
