engine enamel ! need help. - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-08-2004, 03:54 PM
guys, I need help finding the best engine enamel out there that wears good and most of all,TEMP. RESISTENCE. I have a 1969 firebird 400.It seems like within a few months the paint In the middle ports of the exhaust start to discolor. and help please.?
Old 10-08-2004, 05:31 PM
DoubleVision's Avatar
It discolors because it`s the hottest area. have you tried VHT?
Old 10-08-2004, 05:39 PM
fat50's Avatar
Kenneth Howard hates me...
Last journal entry: Engine mock up
Even the factory paint discolors on the exhaust side of the heads.
Dupli-color sell an engine paint that has ceramic in it, Supposed to be good to about 500 degrees. I bought mine at one of the chain autopart stores, got it in black hoping it would hide the discoloration. Havent built the motor yet to say if its good stuff or not.
Old 10-08-2004, 10:16 PM
MI2600's Avatar
Member# 3287
I've had decent luck with PlastiKote (sp?). I like it because you can respray at any time and not have to wait days.
Old 10-09-2004, 12:07 PM
willys36@aol.com's Avatar
Wiki Edits: 21
This has been discussed many, many, many, many, many times on the board. Here are my favorites.
The absolute best finish is powder coating. Takes a little more effort 'cause you need to have the block and heads boiled, take them to the coaters, convince them to not coat vital engine internal stuff (I 'help' them mask my parts!) reboil and water blast the parts (the coaters thoroughly sand blast the parts so they need to be cleaned again), then machine the engine.
A close second is to paint them with the regular automotive three stage - prime/base/clear catalyzed urethane paint you use on the body of the car. Stands up to heat, chemicals and general abuse as well or better than any other finish I have tried, and no other paint finish can approach the quality look.
Old 10-09-2004, 07:44 PM
302 Z28's Avatar
Single stage automotive polyutethane catalyzed enamel. I used PPG's Concept, dries to a rock and great shine. They can mix it to any color, but it's a bit pricey.
Nothing from a rattle can is going to hold up for very long, I don't care what the label says.
Vince
Old 10-10-2004, 02:05 AM
Dupicolor makes a 1200deg paint, in three colors I think.
Old 10-10-2004, 07:06 AM
I agree with Willy's 36 , powder coating is the way to go for hot spots especially... it wont burn off ..
and again i agree,, that normal auto body paints have worked ok for me on my engines,,
