Engine Family - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-25-2006, 08:07 PM
JVunk's Avatar
Engine Family
I Don't Know if this has been asked before. I could not find the info I needed in other threads. What engine family does The 351W Fall into. I am putting one in a 64 Ford F100 and have been looking at catalogs for parts and found a cross member that can be used to mount FE family engines into the truck and was wanting to know if this would work for my Windsor.
Old 03-25-2006, 08:12 PM
Wiki Edits: 31
351 is not an FE, no matter cleveland or Windsor, Or Modefied. heres a site to help you out on ID's for that http://www.fordclassics.com/enginespecs.html
Old 03-25-2006, 11:18 PM
That link has some good information. The 351W is classed in with the small block ford (sbf) family shown as the 90 degree family shown on the link. I did notice they forget (or maybe chose to forget) the laughable 255 built in the early 80's for a couple years.
Old 03-27-2006, 08:11 AM
JVunk's Avatar
Thank you
Thanks for the info it helped.
Old 03-27-2006, 08:24 AM
powerrodsmike's Avatar
Wiki Edits: 161
For what you are doing, any 289/302/351 mount will work. FE mounts are different. So are 351/400 "M" motors. (learned that one the hard way) Speedway motors has a crossmember for that for about 55.00. here's a link:
http://www.speedwaymotors.com/Search...word=916-18013
L8tr,mikey
BE different....ACT normal.
Old 03-27-2006, 05:02 PM
JVunk's Avatar
Thank You You saved me about sixty dollars with that link and info. I had found one in Dennis carpenter for $75 and the mounts were like $83. I appreciate saving money and due to lack of fabrication skills find that this route is easier. Once again thank all of you for the info.
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 06:57 PM
ENGINE BALANCING NAIRB Engine 14 09-06-2011 08:22 PM
1973 Chevelle Malibu Engine Rebuild (pics 56k no) Malibu73 Hotrodders' Lounge 39 11-04-2008 12:37 PM
Build for Hp or Torque? Venturat Engine 76 09-23-2008 10:22 AM
question for any engine builders out there mopar72 Engine 7 11-06-2005 03:06 PM
