Engine frame mounts - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-11-2003, 08:34 PM
J. Cooper's Avatar
Engine frame mounts
I'm putting a sbc stock 350 into a 66 chevy II nova and need to get the right fram mounts for it ,car had a inline 6 in it .Will any chevy nova(60's-70's)frame work?Cost is bit of an issue.
350 engine
350 trans
stock rear end
Old 10-11-2003, 11:00 PM
64-67 V8 frame brackets should do. Complete swap kits (oil pan, oil pump/pickup, frame brackets, etc.) can be purchased from companies that deal in old Nova stuff.
Old 10-12-2003, 04:21 AM
The V8 mounts will work fine, just make shure you upgrade the radiator,use a short shaft water pump,and save your power steering brackets if it has that. I did the same swap a few years ago.The only real problem I encountered was the exhaust system...I had to use fenderwell headers for ground clearance.
Old 10-12-2003, 09:09 AM
J. Cooper's Avatar
Thanks for the info , I also already have my oil pan engine mounts and headers.
