Engine Grounding... - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-04-2008, 12:39 AM
DarknessSpawned's Avatar
God Of Lightning
Engine Grounding...
..n00b question.. Where is the motor grounded. From the battery? The frame?
Old 04-04-2008, 02:20 AM
327NUT's Avatar
I ALWAYS ground my engines in 2 places, from one of the motor mount bolts to the frame and from one of the bell housing/trans bolts to the frame. I make them out of #1 or #0 gauge welding cable with copper battery terminal ends. Overkill I know, but I don't have electrical problems.
Old 04-04-2008, 02:26 AM
I use one from each valve cover bolt to the firewall, standard braided grounding straps.
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 06:57 PM
1973 Chevelle Malibu Engine Rebuild (pics 56k no) Malibu73 Hotrodders' Lounge 39 11-04-2008 12:37 PM
Build for Hp or Torque? Venturat Engine 76 09-23-2008 10:22 AM
Engine....whats it worth? chevyusa1 Engine 6 06-11-2007 06:43 PM
Why high RPM's on the oval tack? steveyb4342 Engine 25 05-23-2007 07:50 AM
