Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - engine hard to turn over by
Old 04-22-2005, 08:08 AM
1quiknova 1quiknova is offline
one more thing, if you do go ahead and rebuild the motor before you do anything install jsut the bearings and crank and torque all the caps, then you should be able to spin the crank by hand pretty easily, if not your clearences are too tight or the crank is warped.
