engine help - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-20-2008, 03:20 PM
engine help
i have a 1985 camaro with a 350 idk what year. it runs good and needs some work but it doesn't have enough power for me. what is a good engine swap choice, either stick with the 350 and work with it or go 2 a big block and a th400 tranny. i can get a 454 with tranny out of a chevelle for 600 bux. any help is appreciated
Old 09-20-2008, 05:06 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Last journal entry: 1999-2001: Getting it on the road
Wiki Edits: 16
A 350 has all the potential that you need, and way more potential than your 7.5" rear axle can hold. A Camaro is already very nose-heavy, so I would steer clear of the big block... especially because most 454s are low compression engines that don't make much more power than your 350.
Build a 350 for it. The stock rear 7.5" rear should handle 350 lb ft as long as you don't go with really sticky tires. Otherwise, look to an aftermarket swap as there are no other easy bolt-in possibilities
Pretty easy to build a 350 up to 450 hp and still be streetable with the right heads and cam, so no need for a big block.
Old 09-20-2008, 06:54 PM
ty
that is something i have considered is to keep the 350 but im clueless as to what combination to use in order to achive 400 plus hp and be street able and use pump gas.
Old 09-20-2008, 08:17 PM
SSedan64's Avatar
Here's a very good palce to look for combo's, up in the 100's now >>
http://ryanscarpage.50megs.com/combos1.html
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 06:57 PM
Build for Hp or Torque? Venturat Engine 76 09-23-2008 10:22 AM
Engine alignment ssmonty Engine 9 07-22-2008 10:10 PM
SF oil???? n-gin Engine 6 07-09-2008 01:37 PM
Why high RPM's on the oval tack? steveyb4342 Engine 25 05-23-2007 07:50 AM
