Engine Help - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-03-2010, 07:17 AM
DARRINGMANESS's Avatar
Engine Help
My son is lookin at rebuilding a 350 motor, my question is its is probably a dumb one but can you put 327 crank & rods in a 350 motor? If possible what are the pros and cons of doing this project?
Old 08-03-2010, 07:28 AM
SSedan64's Avatar
Yes you can. 327 uses a 3.25" stroke Crank & Pistons with different compression height. 350 uses 3.480" stroke Crank.
Pros: Engine capable of higher rpm.
Cons: Less HP/TQ than the 350, Higher cost of valvetrain components for high rpm to equal the cheaper built 350's HP/TQ.
Old 08-03-2010, 07:40 AM
Ok thanks, one more question, as far as the rods, do we use 350 rods or 327 rods?
Old 08-03-2010, 07:50 AM
SSedan64's Avatar
They both use 5.7" Rods, the Piston Pin is located lower in the 327 Pistons.
Old 08-03-2010, 08:08 AM
"my question is its is probably a dumb one but can you put 327 crank & rods in a 350 motor?"
Only maybe. the early 327 had smaller 283 size bearings, 1968 and later 327 has larger 350 size bearings. Check first.
Old 08-03-2010, 08:43 AM
SSedan64's Avatar
Glad you remembered that oldBodyman, as I had forgot.
I think the 62-67 327 Rods/Crank use the small bearing Journal = 2.00" compared to the 68up 2.100" Journal same a 350.
62-67 327 Crank Mains = 2.300"
68up Crank Mains = 2.450" same as 350
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 06:57 PM
Build for Hp or Torque? Venturat Engine 76 09-23-2008 10:22 AM
Engine alignment ssmonty Engine 9 07-22-2008 10:10 PM
SF oil???? n-gin Engine 6 07-09-2008 01:37 PM
Why high RPM's on the oval tack? steveyb4342 Engine 25 05-23-2007 07:50 AM
