Engine help - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-21-2004, 07:36 PM
eM-K's Avatar
New Member
Engine help
I was driving my camaro yesterday... and i was aware that it was idling really low so i was planning on changing the spark plugs. I had to brake hard and my car stalled or something and the wheel locked (its an automatic) and i had to stop and start again. Are these connected? It is something i need to get fixed. What caused it? Also im getting a sputtering sound from my exhaust after its been idling... Are these seperate things or are they all connected in some way.
Old 10-21-2004, 08:09 PM
Siggy_Freud's Avatar
Give us the specifics of the engine. Size, what kind of carb, where the timing is, etc. All of these could be and probably are involved. Done a vacuum check? Fuel pressure okay? Start with the simple things.
Bringing history and technology together.
Old 10-21-2004, 08:23 PM
oldschoolrods's Avatar
Last journal entry: Engine Compartment
It sounds like you have some carb issues to me...what do the plugs look like?
Old 10-21-2004, 08:47 PM
Novaman78's Avatar
Kill It & Grill It
Last journal entry: New door panels
Check the plugs if they are black and sooty then your running rich. This is what it sounds like to me as i just had this problem with my car.
Old 10-21-2004, 09:12 PM
MI2600's Avatar
Member# 3287
"The wheel locked"...steering wheel?
