Engine Help. Engine Turns over Hard, like siezed yet runs awsome. - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-05-2008, 02:24 PM
Hi there, I need help. I have just put a new 383 Stroker in my 1993 Chevy Silverado. I put a Holley 670 Throttle body on and Roller rockers at 3/4 turn from Zero lash. I changed the starter from another old truck and its doing the same thing. I tried timing the truck but when it starts the distributor advances itself, to what it wants. Its hard turning over but when it starts it has lots of jam. Any suggestions would help. Something tells me its the timing, but im not sure. I would take the sparkplugs out and try turning it over but I have alluminum heads and headers on the truck so its extremly hard to take the plugs out. and put them back in.
Old 10-05-2008, 05:45 PM
406 bug's Avatar
9.82 @ 139mph
Maybe too much initial advance. Put a timing light on and see where to begin. Could be poor ground - check starter.
Old 10-05-2008, 06:28 PM
espo1980's Avatar
If it doesn't fit force it!
Is there a ground strap connecting the engine to the body? Without it, it could do what your saying.
Old 10-05-2008, 06:38 PM
71 c-10's Avatar
just a kid and his truck
to set base timing on these you have to disconnect the ignition jumper that is on the firewall under the panel that says junction block. The connector is a single brown wire with a round connector, you un plug it then you can set your timing and then plug it back in.
hot side, 350 tpi engine runs hot on one bank? Ellisb Engine 16 10-27-2002 06:28 AM
Engine stumbles only when I make U turns dion Engine 6 07-27-2002 06:54 PM
Engine turns over but will not start?? Jim Weeks Engine 13 04-06-2002 11:18 AM
engine turns off when the car is put in to gear t623 Engine 4 02-03-2002 09:23 AM
engine turns off when the car is put in to gear t623 Engine 4 01-24-2002 07:33 PM
