Engine hoist problems - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 05-25-2007, 11:26 AM
Originally Posted by pepi
Oh great another hose to keep untangling , i am sure it will work great just seems like you complicate a simple machine and making it less portable. If moving a block around want to bet you run over the air line or have to move it. The hydraulic self contained unit is the better way to go, why reinvent the wheel and complicate the process in the exercise
The thing that is nice with the air over hydraulic cylinders is that you DO NOT need air to operate it, so it is still portable. You can still pump the ram manually and work it that way or use air when it is convenient.
So you can have it both ways.
gcrmcc
  #17 (permalink)
Old 05-25-2007, 02:08 PM
tyman00's Avatar
Bah, forget the manual or air driven hydraulic rams. Just use what I use.
http://www.toyotaforklift.com/produc...maticTire.aspx
With the extensions we made, I can make quick work of moving a car or truck body
Note: If I didn't have access to the forklift I would recommend the pneumatic/hydraulic ram. Save those biceps for turning wrenches not pumping a jack
  #18 (permalink)
Old 05-27-2007, 11:36 AM
[QUOTE=tyman00]Bah, forget the manual or air driven hydraulic rams. Just use what I use.
Some people are just lucky! To bad every one in hot rodding don't have access to a fork lift. I'm jealous!
gcrmcc
  #19 (permalink)
Old 05-27-2007, 01:46 PM
tyman00's Avatar
Don't get me wrong I know how lucky I am. I have had to do plenty of lifting in the past without access to a forklift.
I wish every hot rodder had access to a forklift.
  #20 (permalink)
Old 06-23-2007, 03:30 PM
TexasT's Avatar
Did you ever wonder?
Last journal entry: A little follow up
I am pretty sure once you are at the height you need you are able to diconnect the air line for untethered movement around you work area. The air connection with lever looks just like the unit the tire service I use has in their trucks. You can air up the jack then disconnect and use the same air line to run the impact for r&r the tire.
  #21 (permalink)
Old 06-23-2007, 10:35 PM
Originally Posted by TexasT
I am pretty sure once you are at the height you need you are able to disconnect the air line for untethered movement around you work area. The air connection with lever looks just like the unit the tire service I use has in their trucks. You can air up the jack then disconnect and use the same air line to run the impact for r&r the tire.
Yes, you can disconnect the air line after you are at your wanted height. You do not need the air line to let it down as you still have the release valve just like the manual cylinder. You don't even need air to lift anything. Use just like your manual lift and hand pump it or plug in an air hose and let the air motor do the lifting.
gcrmcc
engine hesitating and other problems 68ford Engine 6 08-18-2006 09:12 PM
84 mustang engine idle problems naarman Engine 1 07-22-2006 09:42 AM
84 mustang engine idle problems naarman Transmission - Rearend 1 07-21-2006 09:43 PM
Engine starting problems, Mopar Steves66 Engine 15 03-18-2006 04:05 AM
Cam Help black66 Engine 3 05-12-2003 07:15 PM
