engine horse power estimate - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-02-2011, 02:55 PM
I wanted to know what the estimated horsepower would be for a 355 with 202 trickflow heads,a mechanical roller top end,12.1 compression dome piston,830 double pumped on a single plane intake,balanced rotating assembly.
Old 08-02-2011, 03:06 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Not enough information, need cam specs.
You'll need more than pump gas with that c.r., VP 110 is probably around $12 a gallon if you buy in bulk, is this race only?
Semper Fi
Old 08-02-2011, 03:24 PM
.600 lift is all I know
Old 08-02-2011, 07:46 PM
cool rockin daddy's Avatar
So did you buy this motor not knowing what was in it or did you build it without a specific power goal in mind?
Old 08-02-2011, 09:18 PM
Might buy it,came out of a dirt track late model.
Old 08-02-2011, 09:19 PM
Last years motor.
Old 08-02-2011, 09:20 PM
Planning on buying one for my Jeep.
Old 08-03-2011, 04:44 AM
Last wiki edit: Building a GMC 702 V-12
Wiki Edits: 44
You want to run the jeep on the road or is it for mud bogging? I don't think that motor is gonna like what your gonna feed it unless your gonna buy $10 per gallon Cam2 or VP racing fuel. And without the cam specs it is gonna be hard to give you any idea of HP but given it is running 12.5 compression and assuming it was built by someone who matched that to the cam requirements and running circle track then I believe it is 500 hp ish +- 50.
Horse power and torque estimate chevydragster83 Engine 21 10-04-2010 12:39 PM
454 power estimate 81malibu Engine 10 10-31-2009 05:31 PM
Horse Power Estimate jmichaelre Hotrodding Basics 11 10-27-2009 11:16 AM
how to estimate Horse Power cliffcliffcliff Hotrodding Basics 4 05-04-2009 08:13 AM
Engine Horse Power Factory. 70 nova Engine 7 02-21-2003 05:07 AM
