engine id - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-13-2006, 02:10 PM
engine id
does anyone know if there is an engine number on a 21 stud V8 Ford, out of a 1933 Tudor sedan, and if so where it is located?
Thanks
Old 10-17-2006, 03:28 PM
Flathead Ford V8 engine ID numbers
For the most part Ford flatheads do not have engine ID casting numbers like many late model engines.
The 1932-37 21 stud engines and the early 38-42 24 stud engines have no markings.
The 45-48 engines are marked in various ways "59" "59A" "59C" on the cast in block bellhousing. Even these marks do not guarantee what you have any more than head part numbers cast into the heads. There were replacement "59" blocks sold with the 3 1/16 bore as replacements for the earlier 85HP engines rather than the 3 3/16" bore indicated by the "59".
The same pretty much applies to the 49-53 engines.
There is so much interchangeability of parts that you could be the owner of a full race flathead with a Mercury 4" crank offset ground to 4 1/4 and overbored 100 thousands using with modified iron heads so you would never know until you opened it up and used a measuring stick on it!!
ENGINE BALANCING NAIRB Engine 22 01-23-2016 01:44 PM
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 06:57 PM
1973 Chevelle Malibu Engine Rebuild (pics 56k no) Malibu73 Hotrodders' Lounge 39 11-04-2008 12:37 PM
Build for Hp or Torque? Venturat Engine 76 09-23-2008 10:22 AM
question for any engine builders out there mopar72 Engine 7 11-06-2005 03:06 PM
