Engine ID??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-28-2010, 10:57 AM
Rodding & Camping-Love It !!
Engine ID???
Trying to ID this engine.
Drivers side rear of block has 350 TBI , pass. front tab on block has V1204PHD with a vin of either (O or C)J17527 47 . I'm still trying to get to to the pass. rear of motor to try & get a casting number. Motor is in car (of course why make it easy)!!!!!! It's "supposed" to be about 89 TBI motor. It is set up and running as a TBI, just trying to track down it's heritage.
Thanks
After more probing I found on the rear of block:
K257
GM5.7LG
10609483
Old 07-28-2010, 01:41 PM
DoubleVision's Avatar
PHD 88 350 Truck 195 L-05 TBI
You must have the casting numbers wrong as there aren`t any numbers that come up. It`s easy to mistaken one number for another.
The 5.7 Indicates right away it`s a 350.
K 25 7 is the date code.
K is the 11th letter, so that`s the 11th month, November, 25 is the date, the 25th, 7 is the year 1987.
Old 07-28-2010, 02:07 PM
Thanks. Thats making a little more sense to me as this is "supposed" to be a late 80's TBI motor.
Old 07-28-2010, 04:48 PM
The picture is starting to gel together!!! Got the trusty Rigid See Snake out and looked & the block casting is 14093638.
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 06:57 PM
Build for Hp or Torque? Venturat Engine 76 09-23-2008 10:22 AM
Engine alignment ssmonty Engine 9 07-22-2008 10:10 PM
SF oil???? n-gin Engine 6 07-09-2008 01:37 PM
Why high RPM's on the oval tack? steveyb4342 Engine 25 05-23-2007 07:50 AM
