Engine ID - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-22-2010, 07:23 AM
Engine ID
First, thanks for the advice with the starter. Shimmed it a couple of times then took out the shims and it's working fine. Not sure what was going on but the shimming was the first thing that got it to turn over.
New question: We were told that this is a crate engine installed about 10 yrs ago. I looked at the vehicle ID and all I can find is MO2O6 (or M0206), then 2VP offset to the left on the second line. The only reference I've been able to find would indicate that the MO is for a 302,not a 350. I can't make heads or tails of the rest. Any help wold be appreciated.
Old 08-22-2010, 09:03 AM
SSedan64's Avatar
Could the P be a B or R?
VB 1969 350 m/t - 255 4 C-10 & 20
VR 1969 350 m/t, 3 spd - 255 4 C-20 & 30
Old 08-22-2010, 06:30 PM
DoubleVision's Avatar
Engine ID Code Example: V0101CLJ - (V = Plant, 01 = Month, 01 = Day, CLJ = Engine Suffix Code)
Another example: T0830CTY - (T = Tonawanda, 08 = August, 30 = 30th day, CTY = 1970 396 Camaro, 375 hp, 11.0:1, TH400)
Code Engine Plant Code Engine Plant
F Flint (Motor) S Saginaw Service
H Hydramatic T Tonawanda
K St. Catherines, Ontario V Flint (Engine)
(McKinnon Industries Canada)
M GM of Mexico
Your block is a target master crate engine as they were made in mexico
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 06:57 PM
Build for Hp or Torque? Venturat Engine 76 09-23-2008 10:22 AM
Engine alignment ssmonty Engine 9 07-22-2008 10:10 PM
SF oil???? n-gin Engine 6 07-09-2008 01:37 PM
Why high RPM's on the oval tack? steveyb4342 Engine 25 05-23-2007 07:50 AM
