I don't reconize that # exactly where on the engine did you take it from ?
Cole |
It can be on the passeger side of the block or the distributer pad Or the rear of the block behind #8. This all depends on what yr it is on placement of the #s. He might have even read them wrong.JMO
Cole |
6x-4 is a 93cc chamber Pontiac head. Look on the head where the two center exhaust ports meet and you will find the casting number, 6X in this case. Look to the front of the head and you will see a boss which has 4 stamped in it. This head has 2.11" intake valves and 1.66" exhaust valves.
BT
I can't find any numbers for blocks cast after 1976, but I know there were some because the late '75 and '76 blocks were thin in the main saddles and they went to a new casting to alleviate the problems that were created. The inferior blocks were casting number 500557. Any other 400 block (400 will be cast on the right side) should be okay. Someone did post the casting # of the later blocks, but I don't know if it was on PY or one of the other Pontiac forums.
Bill |
The following is from “Rick” of the tech staff on Hitman's Pontiac Trans Am Forum:
| the history of chevy v8's | savman1 | Hotrodders' Lounge | 43 | 03-02-2012 06:57 PM |
| Build for Hp or Torque? | Venturat | Engine | 76 | 09-23-2008 10:22 AM |
| Engine alignment | ssmonty | Engine | 9 | 07-22-2008 10:10 PM |
| SF oil???? | n-gin | Engine | 6 | 07-09-2008 01:37 PM |
| Why high RPM's on the oval tack? | steveyb4342 | Engine | 25 | 05-23-2007 07:50 AM |
